Survey123 Not Publishing When Adding New Questions
279
03-11-2025 08:25 PM
Camille
Every time I try to add a new field to my form in Survey 123 Connect and try to publish it it just continues to load forever until I finally give up. I have started my form over a few times and the most recent time I just changed one letter in the name and it still won't publish.
Please help.
Reuben
hi Camille,
Before you can re-publish your form, first, try and delete the previous Survey Folder along with its Feature Layers in your ArcGIS Online Content. (Permanently Delete it from Recycle Bin as well)
ZachBodenner
MVP Regular Contributor
Before deleting anything, did you by chance ever move your survey from one Portal/AGOL folder to another? This can be done kind of accidentally if you reassigned ownership of the survey. If it's in a different folder, you wont be able to overwrite it, but you wont get an error either, just a bunch of spinning.
If this is the case, what I do is move the survey back into the folder that gets created when you first publish it, then re-publish, then move it back to wherever it needs to be in Portal/AGOL to make it do the things it needs to.
Happy mapping,
- Zach
