Survey123 - Leading Zeros for integer
4710
04-23-2020 10:36 AM
PanGIS
Hi guys,
I need to format a field to 4 digits in this way:
the user would input a number and
if 1 ----> the resulting number is 0001
if 12 ----> the resulting number is 0012
Is it possible to format this?
the field type is an integer and I put a length limit to 4.
thanks!
IsmaelChivite
Esri Notable Contributor
This would do the job, assuming that your integer question has nu for name.
if(string-length(${nu})=1,concat("000",${nu}),if(string-length(${nu})=2,concat("00",${nu}),if(string-length(${nu})=3,concat("0",${nu}),${nu})))
For example:
typenamelabelcalculationbind::esri:fieldType
integernuA numbernull
calculatenu_trailA number (trailing 0)if(string-length(${nu})=1,concat("000",${nu}),if(string-length(${nu})=2,concat("00",${nu}),if(string-length(${nu})=3,concat("0",${nu}),${nu})))esriFieldTypeString
IsmaelChivite
For example:
PanGIS
Sorry for the late answer: it is exactly what I was looking for!
