Hi @Anonymous User , thanks for the response. There is currently no WHERE clause on the test version of this survey for simplicity sake. However, on the production version, there will be a WHERE clause to distinguish records for each of our land offices (there will be 17 total surveys hitting the same feature service, the max records ever being called being about 5,100 out of the 30,000).
I tried the List tab refresh on both Survey 123 3.13 & 3.14 for desktop in Windows as well as S123 3.13 and 3.14 on my iPad and iPhone (iOS 15). I got slightly different behavior in both platforms. I tried this with and without the 'Spatial Filter when Map tab is Visible' option and the same behavior with both settings occurred.
In both Windows desktop versions of S123, a list tab refresh will start and the app will get hung up about a minute in (shows 'Not Responding'). I didn't quit either the 3.13 or 3.14 app, but I let them both sit for another five minutes and eventually all inbox records refreshed (~8,000). This hang up while calling the records happened in both 3.13 and 3.14. Is this expected behavior?
However, on the iPad and iPhone, the list tab refresh of the inbox caused a crash in both 3.14 and 3.13. When I reopen S123, there are no records in the inbox. In theory, our users would go open their respective survey, hit the list tab refresh, and have all records available to them for update.
I am not sure if it's our complex service or an iOS issue or both? I can email the logs if you'd like, not sure how helpful they may be.
Thanks for any insight! I am really hoping to figure out a solution before our field season ramps up here shortly.
-Morgan
