URIError: URI malformed at decodeURIComponent () at _setSurveyRow (/home/ec2-user/libs/survey123-formConverter/dist/modules/json2xls.js:1:11234) at r.questions.forEach (/home/ec2-user/libs/survey123-formConverter/dist/modules/json2xls.js:1:3547) at Array.forEach () at Promise.resolve.then.then.then.then.e (/home/ec2-user/libs/survey123-formConverter/dist/modules/json2xls.js:1:3082) at tryCatcher (/home/ec2-user/libs/survey123-formConverter/node_modules/bluebird/js/release/util.js:16:23) at Promise._settlePromiseFromHandler (/home/ec2-user/libs/survey123-formConverter/node_modules/bluebird/js/release/promise.js:547:31) at Promise._settlePromise (/home/ec2-user/libs/survey123-formConverter/node_modules/bluebird/js/release/promise.js:604:18) at Promise._settlePromise0 (/home/ec2-user/libs/survey123-formConverter/node_modules/bluebird/js/release/promise.js:649:10) at Promise._settlePromises (/home/ec2-user/libs/survey123-formConverter/node_modules/bluebird/js/release/promise.js:729:18) at _drainQueueStep (/home/ec2-user/libs/survey123-formConverter/node_modules/bluebird/js/release/async.js:93:12) at _drainQueue (/home/ec2-user/libs/survey123-formConverter/node_modules/bluebird/js/release/async.js:86:9) at Async._drainQueues (/home/ec2-user/libs/survey123-formConverter/node_modules/bluebird/js/release/async.js:102:5) at Immediate.Async.drainQueues [as _onImmediate] (/home/ec2-user/libs/survey123-formConverter/node_modules/bluebird/js/release/async.js:15:14) at runCallback (timers.js:763:18) at tryOnImmediate (timers.js:734:5)
I had the same issue and was able to get around it by removing the % character in my questions, specifically the hint. Not sure why but that did the trick for me.Hope it helps!
Can confirm this works.
Just went through 31 "%"'s on my survey and changed them to "percent" and low and behold, that fixed it. Thanks for the heads up.
ESRI needs to check their javascript, this is a big issue.
I am also having this problem.
Hi @MoonLe , @SierenErnst ,
Addressing these issues is best addressed by opening a support ticket with Esri support.
