I am trying to establish two filters that go to two different Google Sheets based off a field that represents different damage assessment types. I am curious if anyone has been successful in establishing filters from S123 to Google Sheets. I have attached a screenshot of my workflow diagram.
Hi Eric
I've tested a simple scenario similar to yours and both filters worked as expected (please see attached) with rows being added to each sheet. What behaviour are you seeing with your scenario?
Best regards,
Jim
Jim,
I was able to get it. I was using "Text Operations Equals to" when it should of been "Text Operations Contains". I believe that was the issue I was encountering.
Eric Shreve
Thanks Eric, that's great to hear it's resolved.
Kind regards,
Jim
