Good day everyone,
I seemed to have changed the basemap that prints in feature reports. Please help me change it back to the default.
This is what I'm getting:
Hi Michelle,
You can specify the preferred webmap by using the mapsettings parameter in the report template. If you do not specify a specific web map, the default basemap of your ArcGIS organization will be used. Please read this online doc for further information regarding the basemap in your report template.
Hi Michelle,
Thank you for your response.
After several tries, I ran the report with only the map in several configurations and found that my document was corrupted.
