Survey123 Error
1441
04-14-2025 11:07 AM
Gabrielle_Byczek
I am unable to open the survey via other applications
Why is this if, it public and in my name as the owner?
Gabrielle_Byczek_0-1744653969733.pngGabrielle_Byczek_0-1744653969733.pngGabrielle_Byczek_1-1744654013593.pngGabrielle_Byczek_1-1744654013593.png
I am trying create  a pop up on a public facing map:
<div style="text-align:center;">
<span style="font-size:large;">Street Name:&nbsp; {NAME}</span>
</div>
&nbsp;
</div>
<a target="_blank" rel="noopener noreferrer" href="https://survey123.arcgis.com/share/6ba82fca211c4484af4c9b0faf8f9bc2? portalUrl=https://gis.memphistn.gov/portal&amp;field:Parent_GUID_text={GlobalID}&amp;field:From_Street={FROMST...}">ADOPT THIS STREET</a>
</div>
Survey that works:
https://survey123.arcgis.com/share/6ba82fca211c4484af4c9b0faf8f9bc2?portalUrl=https://gis.memphistn....
TylerGraham2
I notice the URL isn't going through an encoder.  You probably need to use Concatenate and UrlEncode to get it to work. I've attached an example of how I use those functions to create 3 different properly encoded links in a pop up to create a new survey, update a draft, and edit an existing survey in Survey123.
Here's a link to the arcade function reference, just search for UrlEncode and Concatenate to get more info on their function.  Just note that in my arcade script below there's a note about q:where needing to be formatted a certain way because the encoder doesn't output the properly formatted parameter. You may or may not experience that issue with your field: parameters. Just a heads up.
TylerGraham2
Gabrielle_Byczek
Thank you so much! I got it to work by removing the ? question mark and readding it again! I will definiely save this information!
