MS Power Automate not showing dynamic content fields for survey123
24262
12
08-17-2020 04:33 AM
Bryan_Wade
I have created a flow using MS Power Automate. It pulls the information from a survey in Survey123 when a response is submitted. It then populates a SharePoint list. The dynamic content was visible in power automate when I initially set up the flow. Everything worked like its supposed to.
I realized I needed to capture additional so I added some fields in the SharePoint List to capture additional information from the survey. However when I went to edit the flow and add the additional fields nothing was showing up in the dynamic content. I double checked to make sure I was logged into Survey123 in Power Automate, I restarted power automate after signing in and out of Survey123. I restarted SharePoint, and still no dynamic content fields from my survey.
Here is a picture of what I am experiencing
As you can see the survey fields are not populating in the dynamic content. How do I rectify this disconnect between the Survey123 and MS power Automate?
ScottBrown1
I have had similar reoccurring issues.  Try logging into Power Automate, select Data from the menu, then Connections.  Go to Survey123, click on the "..." (More Commands) and select Switch Account. Log back in under the original account.  This should reconnect your Power Automate to Survey123 and display your dynamic content again.  It's worked for me several times, hope it helps!
JamesTedrick
Esri Esteemed Contributor
Hi Bryan,
This question deals more with Power Automate functionality - it may be more useful to look for a similar situation in that product's forums.  I haven't seen a similar occurrence in my use of Power Automate.
ChrisShuck
Hi James,
I have several recently created surveys which do not have dynamic content available in Power Automate. Those same forms have the same issue in Integromat. I have been able to create test forms that don't have this issue. It seems about half of the new forms I create have this problem. I've been using Survey123 and Flow for years but have never run into this issue until recently. I've scoured the Power Automate forums but haven't been able to find anything helpful. Could this be related to recent Survey123 updates?
ChrisShuck
I filed a case with Esri customer care, and they were able to figure it out. In my case, the issue was that a couple of begin repeat and begin group fields did not have labels. Once the labels were added and the surveys republished,  I again had the ability to create Flows and use dynamic content. I had gotten into the habit of not adding labels to some repeats and groups with repeats. It flattens the repeat and saves space to not have them; it keeps each record on one screen without having to scroll down. That makes it easier to navigate between repeat records. While it is unfortunate that I can no longer do that, it's a small price to pay to have the ability to create Flows again. A big thank you to Katelyn at Esri Customer Care!
FrankMartin1
I just wonder if anyone had found an answer to this issue.  I have the same problem with Flows that I previously created that now do not show the dynamic content.
ScottBrown1
butterip
That worked for me too. Thanks!
I also noticed I had several connections to Survey123 listed. I deleted all but one to clean things up.
DavidForbuss1
This worked for me!! Thank you so much for posting it.  I had taken to just creating new connectors if I need to change any of the dynamic fields...this saves me LOADS of time!!
NLI_Wendy
I wonder if this is set up differently now that it is a few years later? I am having this same issue but I am not finding where you select "Data" from a "Menu".
andrewdfahey
@NLI_Wendy I hit the same issue since I don't live in the Power Automate space. Found it just a bit ago and wanted to add it here in case anyone else stumbles into a similar issue since you may have found it by now. Along with what other folks have said, once I "switched accounts" dynamic content worked again for me
