Survey123 Crashing
76
Thursday
GabriellaAbbott-Gribben
My survey123 form has started crashing, I had a very similar form last year and had no issues with the app crashing and since surveyors have been out this year I have had multiple reports of it crashes losing data. We've tried to recover the data using SQLite files but there is no data there either. This has mostly been happening towards the end of them filling out the form.
The major changes to the form have been:
  • Using the body::esri:visible column instead of relevant for question visibility because when we used relevant this year it meant data was being erased from the form if surveyors left the form and saved in drafts
  • Adding file names to the photos
Surveyors mostly access the survey123 form through a link from fieldmaps.
I do not have any logs nor have I been able to replecate the crashes myself.
I've attached both forms .xlsx files V4 is this year V3 is last years
DeonLengton
Hi Gabriella
It is going to be hard to troubleshoot this without a log file.
I would definitely suggest that you try to get that sorted.
Having said that, what I have found personally is that sometimes a text field gets too long and it gets that truncate error. On other occasions I had badly formed html in my survey. But those are the only times I had issues like yours.
