Survey123 crashing when attempting to add image
3793
11
07-11-2017 09:00 AM
BradenBurkholder
Is anyone else experiencing issues when attempting to add an image to a survey? Specifically, adding a previously captured image, i.e. Select an Image (folder icon) brought up the following issues:
First, I had to find the location where my default camera (Samsung Android device) was storing images. The default was /storage/emulated/0/Pictures, my images were at /storage/emulated/0/DCIM/Camera. I do not believe this was the case in field app version 2.0.56, but I could be mistaken. I didn't test for this issue in 2.1.9.
Second, anywhere from 6 to 10 images will load and scroll, then the screen will go black and the app crashes. I do have hundreds of photos in this folder, but I'd guess that's pretty normal for most users. The default sort order may be ascending by name or date/time, but either way the most recent photos are (inconveniently and inaccessibly) buried at the bottom. A descending sort would be nice, but the app crash would still be an issue.
Potentially important info:
Android version 6.0.1
Survey123 field app version 2.2.15
Similar issues: Image Selection in Survey123 App (see comments as well)
ZachMueting
we ended up taking images out of surveys because it would always crash the program.  it seems to be very sensitive to how big the image is and even the new image sizing option in connect did little to make it work.  the image upload option is too inconsistent for us to count on for clients.
WASA
This issue still seems to be prevalent on the Samsung Tab S5e is there any fix for this using survey 3.18.142
