Survey123 Constrains Formula
1088
07-02-2020 06:56 AM
ShawnRoberts1
Probably an easy one, I've just been out of the survey123 game for a while so my syntax is a bit shaky.
I have a primary type drop down which a user can choose a primary type (select_one).
After that the user is able to select other relevant types (select_multiple). This list is basically the same list as the primary type, just its a select multiple.  Ex primary type could be Community Center, and the secondaries could be arena, agricultural hall ect.
I'm just trying to write the constraint formula to ensure the select_multiple does not have the value in the select_one checked off. So if Community center is the primary type make sure its not also selected as a secondary type.
If this has already been answered well somewhere else feel free to point me to it!
ShawnRoberts1
yup answered my own question.
not(selected(., ${faciltyTypePrimary}))
Dug it out of How To: Constrain Select Multiple response combinations in Survey123 Connect for ArcGIS  and modified it for my own needs.
ShawnRoberts1
