Survey123 connect Using one answer to autofill another
4675
05-20-2022 09:11 AM
Kjcomp10
Alright Survery123 community I need your help.
I am trying to have one survey question answer another survey question from a choice_list or a .csv or even a feature service.
Here is the situation.
The survey will ask the users what location they are at. When they answer each location has a specific site code associated to it. I would like the correct site code to auto-populate when the location is selected.
From what I can find this is possible using the appearance search functionality in the form.
Here is the link to using the search() appearance
I have tried to follow this format but clearly I am doing something wrong.
search(‘tableName’, ‘searchType’, ‘searchColumn’, ‘searchText’, ‘filterColumn’, ‘filterText’)
Any help would be wonderful.
I have attached the forms below. Since i am doing this wrong I cleared the appearance column out to start over.
AndyMcClary
Hi Ken,
If I'm understanding your question correctly the pulldata() function should do what you want. Try putting something like:
pulldata(Armories, sitecode, name, ${armory})
in the calculate column of the sitecode field and you should be good to go. Documentation on the pulldata function is in the Work with external content section of https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformformulas.htm
Katie_Clark
Hi Ken,
Where is the CSV file located that you are pulling data from? Is it hosted in AGOL? Stored in the media folder?
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
Kjcomp10
Hey Katherine,
I created the csv and saved it in the media folder.
The other option here is that this information is also in a point feature service in our ArcGIS server which is federated to our portal enterprise.
AndyMcClary
Hi Ken,
Kjcomp10
I will give that a go and let you know if that works out.
Thank you for the help.
Kjcomp10
Thanks Andy,
pulldata(Armories, sitecode, name, ${armory}) worked great just needed to add ''.
So..
pulldata('Armories', 'sitecode', 'name', ${armory})
I appreciate your help.
