Survey123 Connect pulldata(@layer function
1698
07-23-2024 05:37 AM
TKSHEP
Is there a way to use an If statement when using the pulldata(@layer)?  The layer is polygons, and I am trying to use pulldata("@layer", "getValueAt", "attributes.area", "https://hostedfeatureserver.com", ${device_location}, "") and if device location is outside one of the layers boundaries then instead of the attributes.area use text  the "International".  How would I use the calculation to do this?
abureaux
MVP Frequent Contributor
Just linking this to a similar thread where @TKSHEP posted the same question.
abureaux
TKSHEP
Is this something you can help me with?
