Survey123 connect Publishing error unable to add feature service definition
842
12-21-2023 10:47 AM
OgunfolajiDare
Please, I need help in publishing my survey. I have tried several times it keeps saying unable to add feature service definition.  Code: 400 index was outside the bounds of the array. Attach image was the displaying information .
ChristopherCounsell
MVP Frequent Contributor
Can you share the form?
ArcGIS Online or Enterprise?
New or republish?
OgunfolajiDare
survey123 connect
ChristopherCounsell
The error you are seeing is not a common one. I believe it's a response from the server.
Uncommon errors are often associated with workflow or environment.
To be able to assist we need more information like are you publishing to ArcGIS Online or Portal for ArcGIS as part of ArcGIS Enterprise? Are you publishing a new survey or updating an existing one? What version of Survey123 Connect? Do you have issues with publishing other surveys, or from different devices or apps like ArcGIS Pro?
Can you provide the XLSForm?
Otherwise technical support will be able to search their database for cases with this error message, specific to survey123
