Survey123 Connect Missing Sample Templates during create.
1679
07-18-2023 03:59 AM
DanielLoegelCMS
Not seeing the sample templates anymore when creating new Survey123 in 3.18.123 after installing this version. Have these been removed from Connect? These templates are very helpful when trying something new.
ZacharySutherby
Hello @DanielLoegelCMS
If you or someone who is an administrator in your ArcGIS organization logs into the Survey123 website and navigates to Organization > Settings > General is "Templates and samples from Esri" or "Templates from the Survey123 community" enabled under the "New surveys" section?
If you are in ArcGIS Enterprise and are using the Survey123 local website installer you may need to go through the Configure an installed ArcGIS Survey123 website in disconnected environments workflow to have access to the samples and templates.
Thank you,
Zach
ZacharySutherby
Thank you,
Zach
DanielLoegelCMS
Zach,
That did the trick, got the AGOL admin to make the change and I now have access.
Much appreciated!!
Dan
