Survey123 Connect: If question A is answered "yes", populate Question B with a calculation; otherwise leave it blank
5969
15
05-08-2018 08:25 AM
MatthewCarey
In Survey123 Connect (2.6.4) I'm struggling with getting the form to perform a calculation in a question only if I answer yes to an earlier question.
I have a select_one yes_no question ({samples}) which is "Did you take samples today?"
If the answer is yes, I would like it to generate a sample number (text, in the field sample_coll_no) which concatenates text that's already been entered by the user such as county code, target pest, and date. It has this in the calculation column: ${county}+"-"+${targetsci} ..... and so on.
So when, using the 'relevant' column, I make sample_coll_no relevant only when ${samples} = 'yes', or make the group that it's in relevant only when ${samples} = 'yes', it doesn't populate it in the form; there doesn't seem to be a triggering event that would make that happen.
If I make the 'relevant' column blank for the sample number question, it performs the calculation whether or not the "did  you take samples" question is answered yes or no. And I don't want a sample number filled out when none was taken.
I'm not sure if it makes a difference but this survey is for filling in fields in a related table; the main point feature layer is trap locations and this related table is for the site visits; there will be multiple site visits for each site/trap.
Can anyone suggest a different approach to my problem?  It seems like a somewhat standard thing that I'm trying to achieve but somehow I'm not getting there.
Thanks!
JasonJordan00
Hi James, I'm using  3.5 and I'm still seeing this behavior. I have a hidden field and if it becomes relevant, I want it to return one of two values, otherwise leave the original data in the field (since we heavily open past surveys up in the Inbox).
I can't share my form but I'll show the relevant and calculation columns.
Relevant                              Calculation
${tflOnsiteStatus}!=''if(${tflOnsiteStatus}='No Issue','No Issue','Unresolved')
No matter what, it always returns "Unresolved", even if tflOnsiteStatus is blank. I have tried several different relevant expressions to see if any worked.
DougBrowning
MVP Esteemed Contributor
Often when people have this issue they are checking the label value and not the Name value.  Since you have a space in there I wonder of that is it.
JasonJordan00
Thanks for the suggestion but I should have clarified. The label and name values are the same. The calculation itself works. The problem is is just runs regardless if its supposed to be relevant or not.
JamesTedrick
Esri Esteemed Contributor
Hi Jason,
Based on your description, I would expect it to return 'Unresolved' if tflOnsiteStatus is blank.  The built-in if() function cannot preserve an existing value (i.e., 'replace this only if this condition').
MichaelDepow
Hey James I have question for you if you have the time.  I have a select_one question called select_one normalCircum and I also have that in my name column normalCircum
In my choices tab I have normalCircum and 2 options for it Yes and No.  What I want to happen is when you select No a text bar appears to allow you to explain why.  Do you know how I can do this?  I've attached some pictures to help hopefully
MatthewCarey
Hi James,
Thanks for the quick reply, much appreciated. Unfortunately in Survey123 on my iPhone I've been having trouble getting the 'recalculate' button to appear, I couldn't get it to work as you describe. The only time it would come up was when I'd added a second site visit and then erased it again, which did force the calculation in the sample_coll_no field to happen. Then when I erased a character from the end of the calculated string, the recalculate button appeared.
Other than that it's very reluctant to appear. Am I doing something non-standard, perhaps?
