I am trying to have a map thumbnail show in my published survey. Currently, there is only a crosshair and map icon with the question. Is there something I can change in my Survey123 Connect form to display the thumbnail?
That's the GPS and Basemap selection tool, that you'd usually see alongside the map.
Do you want a thumbnail? I don't think that's a thing within the form... Maybe you'd get it if you were changing the Basemaps and the map/thumbnail was one of the options.
Are you trying to add a custom map to your form? More info on that here:
If the map is just not working, can you share your form or provide more info?
Thank you for the reply, Christopher! It started showing up on the actual survey. Not sure what I did but it works now.
