Survey123 Connect concatenate date and pulldata result
3986
11
08-15-2024 11:45 AM
Elizabeth_Burniston
This is probably much easier than I am making it. I need to concatenate the year with a number generated from a pulldata calculation. It needs to read like this 24-xyzx. I know this is not the right syntax but essentially like this; %y-${formno}. I believe this needs to be in the constraint field... where I have the question marks. I receive the correct result in ${formno}, I just need to join this to the year. Let me know if you need more information! Thank you!
DuncanC
Yeah, you can't just throw a date format string into a concat like that.  Make a hidden datatime field if you don't already have a date field to grab the year from, set it's default to now().  Then a hidden field that uses format-date as the calculation so it's value will be 24. Then concat that with your pulldata value.
https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformformulas.htm#ESRI_SECTION2_AF58C02...
It should be possible to do it all in one line, but the XLSX parser in Survey123 connect is kind of broken, when I try that it never works, so I just use lots of hidden lines and do one thing per line.
ZachBodenner
MVP Regular Contributor
It looks like your pulldata is working, yes? If that's the case, it must be in the calculation column - is your concatenate in the calculation column as well?
Happy mapping,
- Zach
Elizabeth_Burniston
Yes... my pulldata is working and yes... it is in the calculation column. Is concatenate actually what I need to give me the result I want? I just assumed it was, but I was putting it in the constraint column.
ZachBodenner
Constraints will essentially make it so that any entry outside of the specified format wont be allowed. I think it should work if you put it in the calculation column and format it something like this:
concat(%y, '-', ${formno})
Happy mapping,
- Zach
Elizabeth_Burniston
I am getting an error... couldn't understand the expression. I am concatenating a date with an integer into a text field. Does that matter?
DuncanC
ZachBodenner
Mm, that's a good catch. I routinely overestimate what 123 Connect can do in those kinds of calculations.
Happy mapping,
- Zach
Elizabeth_Burniston
Thank you for getting me on the right track though! I appreciate your super quick responses! 🙂
Elizabeth_Burniston
That worked! Thank you!
Elizabeth_Burniston
@DuncanC - Hi again! I just noticed that in Connect the solution works exactly as it should, but when I look at it in the webform, it gives me "Invalid Date". I could have SWORN it worked before. By chance, is this a Connect version problem? Since we worked on this, I upgraded to the most recent version of Connect.
