Survey123 Connect 2.6.4 Crashing when signed into ArcGIS Online
3101
10
01-30-2018 08:48 AM
PaulPanehal
I am writing this to potentially report a bug.
I am running Version 2.6.4 of Survey123 Connect, and it runs perfectly fine when I create and run surveys locally. As soon as I log into ArcGIS Online (AGO) and open my existing survey, Survey123 crashes.
At first I thought this had to do with certain fields that I had added, but this does not seem to be the case.
I have attached the three log files that all represent attempts to login withing minutes of each other. The smaller files seem to indicate why the program crashed.
by Anonymous User
Not applicable
Out of curiosity, when Connect crashes, do you get a crash window and if so can you expand the problem details (like below). I woudl be interested to see what the Fault Module Name is. Can you send screenshot please?
Phil.
