Survey123 - Auto Calculation works in Connect and the Survey123 App but not in the Web Broswer version of the form
1530
12-15-2021 02:34 PM
RickeyFight
MVP Regular Contributor
I have a form to add two text questions together. I have the First and Last name in one question and address in another.
The calculation I am using is  ${prop_owner_name1}+", "+${project_address}
This calculation works as expected in both Survery123 Connect and the ArcGIS Survey123 app however if I were to open the survey in a web browser, the answer gives a NaN.
I am using Survey123 connect 3.13.251
DougBrowning
MVP Esteemed Contributor
No cannot use the + at all.  Just comma separated list.
concat(${prop_owner_name1}, ", ", ${project_address})
Bookmark this page as your new bible 🙂
https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformformulas.htm
DougBrowning
for strings you have to use concat() for the web browser.
RickeyFight
@DougBrowning
Thank you for the quick reply. Am I doing this wrong
concat(${prop_owner_name1}+", "+${project_address})
I tried this and it did not work.
DougBrowning
