Survey123 | Appearance | Compact | for Repeats
741
09-08-2023 01:24 PM
MichelleWilliamsERM
In previous versions of Survey123
We could compact a repeat, and if the field crew didn’t open the set of questions, the record wouldn’t populate with NULL data.
Version 3.18
This version adds a record of NULL values, which does two things;
  • It makes the report ugly by adding a record for the NULL data (unless you add an if statement)
  • It will also charge us more credits for having NULL data in the cloud.
Let me know if there is a fix in the works for this OR is there something I'm doing wrong?
@MichelleWilliamsERM
abureaux
MVP Frequent Contributor
Have you tried adding a select_one yes_no before the repeat? If they want to add records they select yes. This would dynamically hide or show the repeat. I normally do this and make my repeats required. At the absolute least, I find that it makes the interface cleaner and helps promote more reliable data collection.
When a thing isn't relevant, it technically doesn't exist, so the program may see it differently than just a "collapsed repeat". However, I am not sure if this would resolve the null you are seeing, but may be worth a try.
abureaux
MichelleWilliamsERM
Thank you,
I didn't even have that on my radar, I will put that into place! Once I make sure it works, I'll mark it as the solution.
