Survey123 and Make (formerly Integromat)
6853
13
03-08-2022 07:12 AM
ShelbyZelonisRoberson
Hi, I currently use Integromat for some Survey123 workflows. I have a survey where upon submittal, a report is generated and emailed as an attachment to certain users based on a spatial intersect done on-the-fly.
I got a notice from Integromat that they are upgrading to a new company called "Make" and stopping support for Integromat in 2023. Before I upgrade to Make, can someone on the Survey123 team verify that it will still work the same way? Has Esri done any testing?
Thanks!
JD1016
That's interesting.  Do you have the HTTP-Get a File module in your scenario?
Yep I do, right before the Email, same as yours.
JD1016
Okay.  Can you provide a screen capture of what you have for the Email attachment portion?  Also, is your HTTP information the same as mine?
FedericoRiet_Sapriza
I'm currently using Make and works great.
I have a Q regarding the configuration, in my Survey123 the user sends some data using the mobile app , and later few hours to day, the user edits (add new data) and re send the data using the mobile app.
What happens in google sheets, is that the info is repeated, it adds a new row  with the same info+ new added data
Is there a way to avoid this?
Cheers,
Federico
@IsmaelChivite
