Survey submitted from several different Tablets.
1158
7
03-12-2024 06:51 PM
Reuben
hi,
I had a survey where different sections were filled by 5 people using
5 Tablets.
After retrieving the 5 Tablets, I began uploading each section of the survey
from tablet 1 to tablet 5. Submission was successful.  But when I check the survey data
in my Survey page, only the data from one of the 5 Tablet was in the table. Data submitted by the other
4 Tablets were missing.
Question is, What could I have done wrong ? What could have been the problem?
Appreciate any response
abureaux
MVP Frequent Contributor
ngl, I always set it for all rows since it's faster and easier.
Technically you can use it more sparingly, but unfortunate I don't recall where the guidance document is for query parameters. Here are the couple I remember off-hand:
  • Very important to set this for Begin Repeat.
  • I think that setting query allowUpdates=true for Begin Repeat carries down to all items within the repeat, making setting it for those items within the repeat redundant (I still do anyways...)
  • You cannot set a query parameter for a blank row (you will get an error when you save the XLSX Form).
  • There is no need to set query parameters for End Group/End Repeat.
DougBrowning
MVP Esteemed Contributor
Were they all from the inbox or something like that?  If so the last survey would overwrite the final.
Reuben
They we're saved in the Out Box. I upload from the Out Box
abureaux
I have not seen that behaviour before. It would help to see your XLSX.
Did you see the values entered into the S123 Field App, and then after submitting they didn't make it to the database? Or were the values just not in what the tech saved?
Reuben
Yes all values were entered and saved in the Out Box of the Field App. I upload the Values from the Out Box
in the Field App.
abureaux
Hmm. Did you set query parameters? That can result in blanks if not set.
And of course a field set to null can do that too.
Reuben
hi,
Thanks. The query parameter to be set for
all rows?
abureaux
