I created a survey using the web designer, and published it. When I log in, I can see that the survey exists in My Surveys, but when I click on it to see what results I've got I get the error "The survey does not exist or is not accessible."
It worked fine when I first set up the survey a week ago, but has become inaccessible sometime between last week and this week.
This is the public link to the survey: https://arcg.is/05zSG0
Hi Ross,
I'm able to access your survey. Could you delete your cache/browser cookies for the site (or try to access in Incognito mode with your browser) and see if you have the same issue?
