Survey did not submit - red circle with number on thumbnail
1062
07-14-2022 09:17 AM
DanielKonzek
 What does the red circle with a number '1' indicate in the image for the survey titled 'Monarch Monitoring SOP3...'?  The field user attempted to submit a completed survey and it did not go through (the details on exactly what happened when she hit submit are a bit fuzzy).  There is no Outbox shown on the Survey homepage.  The homepage only contains options for 'Collect' and 'Sent'.  The survey that she submitted is not shown in the 'Sent' box and is not in the AGOL feature layer.
Thank you!
Richard_Purkis
@ChristopherCounsell If you click the red circle it should open up the survey submission that failed to send and show the corresponding error
ChristopherCounsell
MVP Frequent Contributor
If you go to Collect, does it prompt you to recover a survey after a crash?
The color indicates the folder. Draft = orange, light blue = Inbox.
Richard_Purkis
ChristopherCounsell
@DanielKonzek this is the correct solution if you didn't see it
