Survey Description- Hyperlinks
1986
11-26-2018 12:27 PM
Lake_Worth_BeachAdmin
The description text before collecting a new survey is often helpful for contact info (emial phone) for support for our field users.
I don't believe it's possible but worth asking...
can I insert hyperlinks in this text box?
(hyperlink to an online hosted PDF for example)
IsmaelChivite
Esri Notable Contributor
Hi. Yes. Totally doable!
Go into www.arcgis.com (or Portal for ArcGIS if using ArcGIS Enterprise). Login and open the Item Details Page of your Form item. Then change the description embedding HTML links.  After than, download again the survey into the app.
IsmaelChivite
ahhh sweet, thanks Ismael Chivite
HélèneTouyéras
Hi @IsmaelChivite , thanks for this tip!
The hyperlink will disappear if the survey is republished (@Survey123Connect, tested in 3.13.251), so that users lose the hyperlink at each update (unless they delete the survey and download it again, instaed of updating it).
=> It would be great if that info page could be retained, or if hyperlinks coming from the Survey123Connect info page were retained.
I have searched if this ArcGISIdea already existed , and have published it here:
https://community.esri.com/t5/arcgis-survey123-ideas/hyperlink-support-in-survey123-field-app-info/i...
Cheers,
Hélène.
