Survey 123 Simple Multiplication
680
07-21-2022 01:38 PM
MeganWheat
Hello!
I am working on a calculation to just multiple an integer field by 1000.
{total_flow2} *1000
this is what I have but of course I get an error. And I have tried it other ways too and just wanting to know how to do this. Please help! Thank you!
Megan
Katie_Clark
You need the dollar sign in front of the curly brackets
${total_flow2} * 1000
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
Katie_Clark
Best,
Katie
MeganWheat
Awesome thank you! I did notice I have to create another field for the calculation to run as well. So total_flow2 is whatever integer is placed in the box. Then I created a calculation total flow area with the calculation. It would not run in the total_flow2 calculation box.
Katie_Clark
Yup, exactly! The calculation returns a result which populates that field, but it can't reference itself, so the output is a different field/question.
Best,
Katie
MeganWheat
Awesome! Thank you so much! 🙂
