Survey 123. Remove inbox items when no longer needed
1487
12-12-2017 07:32 AM
ElaineSchifke
Downloaded items to my inbox in order to edit a completed survey. Once completed how do you remove the items from the inbox. There is a refresh button but no remove button.
How do I do this.
Elaine
BrandonArmstrong
Hello Elaine,
Although there is not a way to target "only" surveys in the Inbox, there is a way to clear all surveys that are complete, incomplete, deleted and submitted from the 'My Surveys' page.  This option is located in the Advanced Settings of the Survey123 field app and should be used with caution.
You can navigate to the 'Advanced Settings' section of the settings documentation linked below for more information...
Settings
If you are not already, would recommend using query expressions in the Inbox Filter to limit the surveys returned to only those ones that you are wanting to edit and resubmit.
Where expressions
