Survey 123 Inventory Manager
1306
01-17-2023 05:07 AM
AntonioBrcković
We are trying to make an inventory manager that scans QR codes and displays the current stock of equipment. Is there a way to make a formula or something in Survey123 Connect that allows us to instantly calculate and display the current stock after we add or subtract a piece of equipment?
We tried using the calculations field and the formula (Quantity_IN - Quantity_OUT) + Stock and although we received no errors the Stock field in our Inventory on the Server is always empty.
Appreciate all the help you can give us.
jcarlson
Referencing existing fields will only work if you are using the form to edit rows. Can you confirm if you are doing that? You'd need a single row in your table for each asset type, and your form would simply be editing the attributes.
- Josh Carlson
Kendall County GIS
