Repeat questions according to the number marked as an answer from another question
1184
01-14-2023 04:29 PM
RaynerCastro
Hello!
I have a survey about route control of a bus service. I created a question that asks for the number of stops made in a journey.
How do I configure the survey so that I can record the number of passengers getting on and off the bus at each stop?
Thanks!
Tags (1)
abureaux
MVP Frequent Contributor
If I understand correctly, this should work for you:
Setting the source of repeat_count to be the number of stops means you will have your repeat records equal the number of stops. Then you simply add the passengers at each stop.
