Survey 123 form Error: Initializing form... Error: not a object
15372
43
05-06-2025 03:32 AM
PaulSweeney3
Hi All
See screen shot below that is appearing intermittently across our forms emebedded in  dashboards
the same dashboards were working fine a few days ago and no changes have been made to either the form or dashboard. it only occurs when the form is opened in edit mode. the globalid is present in the feature layer also .
SteveMartin__MDTA_
I think I figured it out. Check the settings for the embedded object. For me, I had it set to latest. I went back and changed it to my current version of Survey123 Connect which is 3.14. I reloaded the page and it works fine now.
SteveMartin__MDTA_
I too am having the same issue. Today is the first time seeing this.
SteveMartin__MDTA_
bbywaterbw
I'm having the same issue, but my survey is not only in an embed, I'm also doing some url passing. Everything was working yesterday also. My Survey123 Connect is version 3.22.49. I wasn't using any version information prior to this issue and my url string would look something like this:
https://survey123.arcgis.com/share/(survey id number)?center=42.28321263,-87.84173499&field:appurten...
Any suggestions where to slip the version information in? When I add it before the question mark or after the ampersand it makes it worse.
SteveMartin__MDTA_
When I started out in Survey123, every time ESRI made a change it affected me adversely. It took a bit of figuring what was going on before I got the hang of it.
Just a hunch but open your form in the survey123 website and click settings. What happens if you set it to either one of these options?
GISAdministrator_LMCC
gmontero
Thank you. It worked for me.
Marc_Patti
Just tried inputting the "version=3.21" parameter into the survey URL and that did fix the issue (for now).
Seems likely that ESRI pushed some update that threw everything off in the last day.
PaulSweeney3
@SteveMartin__MDTA_ yes thats it must be some browser update or something throwing it out i reverted back to 3.21 and it works for me now.
