Hello, good morning. How are you?
I'm working on a project and I came across a problem. There are some fields that must be completed based on the results of other fields. For example, if the result in field A is greater than 1, the “good” text should be displayed in green; otherwise, the “bad” text should appear in red.
So far so good. I validated this function by previewing the form in Survey Connect, and it was working as expected. I carried out the necessary checks before publication, and there were no errors.
However, during testing of filling in the application, when sending the responses, I received the error “A value passed for the ‘text_brot’ is invalid”. To resolve this, I checked the formulas in the calculation column and they appear to be correct. I also checked the size of the string, which only contains the words “good” and “bad”, so it shouldn't be a size issue.
Initially these fields were set to “Type Note”, but due to these error messages I changed them to “Text”. However, the problem persists. I had difficulty finding similar cases in the ESRI Community. The closest occurrence I found was error 10583 “A value passed for the field X is invalid”, but there don't seem to be any specific solutions for this case.
The fields that present this error are in red, and start on line 439 of the XLSForm.
