Surver123 Unable to Update Survey (WEB VERSION)
293
02-19-2025 09:53 AM
MikeSimmons
Hi there - I am unable to publish changes to responses on Survey123 web version (this survey has never been in Connect).  I had two typos and corrected the misspellings in one of my multiple choice questions.  The error simply provides {}.  I don't quite find this useful.
The survey is active and responses have been collected.  Is this possibly the problem - I can't update responses due to collected data already being present?
Any other insight or workarounds for me to correct the typos and be able to re-publish the survey would be much appreciated.  Thanks!!
TrafficOpsGIS
I would use the hosted feature or a copy of and recreate the survey in Connect. Which will allows you to run the analyze survey tool. This produces an xls file the contains issues and solution suggestion. You should at least be able to tell where the issue is using the above.
MikeSimmons
Thanks!  What I finally tracked down was this was related to the choice list.  I had typos in the choice list, and because data was already populated on that question with the choice, I was unable to update/publish the survey because it didn't recognize either 1.) my updated choice, or 2.) it was looking for the already popluated choices.  I lived with this shame of the typos (hah!), but learned a couple valuable lessons along the way.
