Hello
I've created a survey with support for three languages: English, French and Cree.
I believe all is good with English and French setup. RE: the Cree language I was not hoping for it to work perfectly since Cree does not seem to be supported (can no longer find that link where I read that). My recollection was that for languages that are not supported, it was referring to 100% support meaning that in some cases (e.g. geo questions) the widget instructional text will not be translated.
However, I cannot get any of the translated text to appear as a label. It takes up space on the form but it is not visible; either in S123 Connect or S123 Survey app. Yet, in the Excel form it appears just fine.
ᐊᒥᐢᑿᒌᐚᐢᑲᐦᐃᑲᐣ
Here are some Cree syllabics that I copied into a label field using the Cree (cr) language code; same as I did with French (fr) and it worked as expected.
I'm not looking for perfection but if we can get most of the survey translated (less widgets, etc) that would be worthwhile.
Thanks for any input.
Brian
