Sort an External Choice List in the Survey123 Form
1865
07-19-2023 11:07 AM
RobertAnderson3
MVP Regular Contributor
I have a few CSVs that I am using for multiple surveys, they're only a few hundred rows but because they're used in multiple places this makes my life way easier updating one list instead of several.
My question is, is there a way to have this list sort differently in each of my surveys so the most relevant answers appear at the top on each survey?
Thanks!
IsmaelChivite
Esri Notable Contributor
Sorry. Not possible.
RobertAnderson3
I had a feeling it wasn't but wanted to double check, thanks!
DerrickFreseADF
@IsmaelChivite, is it possible to sort external choice lists at all? We have a csv in Portal that we're using to pull a list from and every time the survey is opened the list is in a different order.
beachcamp
I think your best bet is going to be to either:
  • Filter your lists based on the particular survey in use.
  • Copy the CSV after you update it, for each survey, and sort them individually as desired (I would use a python script to do this personally).
  • Use an autocomplete appearance to make it easier for users to find the desired items.
RobertAnderson3
Thank you for the suggestions @beachcamp !
Was trying to avoid the clutter of copies, but the scripting it is a good idea. And I have been using the autocomplete for it anyways but still want to make it as simple as I can for users. There's like 5-10 options they use daily and then 100 more that might get used once a month.
What I've ended up deciding to do is, I had an "Other" option in my pick list that opened up a text question for free entry, I've set up a choice filter that will show the most relevant + Other for the first question, then changed the free text to a select one that just shows ALL of them for the secondary question if they pick other.
