Signatures in Summary Report
846
03-02-2023 08:34 AM
FreddyCroft
I created a Survey123 to use as a sign-in sheet for events which included a field for the participants signature. Now that I need to generate a copy of the sign-in sheet for official reporting, which needs to include their attached digital signatures, I get the error of:
Error: An error occurred when checking the report template. Failed to parse ${sign | size:400:0:0:200} since printing a map/image or accessing attachment binary is not allowed when looping records inside a summary section.
Is there any workaround or solution to including the signatures in to a sign-in sheet style summary report?
jcarlson
MVP Esteemed Contributor
Not really, no. You'd have to access the repeats in the form rather than use a summary section.
- Josh Carlson
Kendall County GIS
