autopopulate a repeat questions from another repeat question
800
03-02-2023 09:00 AM
Cesar_Aguilera
I want to ask you if it is possible to fill a table of repetitions from another table of repetitions, for example:
In the first repeats table I choose an answer to a single selection question, based on that selection another repeats table will be enabled, so far so good,
I have already done this well, but I want that when the second repeats table is activated it extracts a series of data from the first repeats table, so far so good too,
the problem arises when in the first table that conditions the second one you continue adding more repeats, in the second table it restarts the field count deleting the first automatic record previously generated.
