Showing submitted records on map
1209
03-25-2022 10:14 AM
by Anonymous User
Not applicable
I'm hoping I can duplicate this in some small way-
https://cpworkshop.mysocialpinpoint.com/central-williamson-creek-greenway#/marker/155237
I know these folks at mysocialpinpoint.com have put in tons of work to make this looks so flashy, and I appreciate that.  I'm really looking to do something similar only in the sense of showing previous records on a map they're about to draw on.  The goal here is of course to keep repeating records from showing up, I don't want to see 400 of the same point and description.   So if someone sees that the pin has already been placed in a location, they can move on to another.
Hopefully I've described this well enough.  It all sounds so much better in my head.
ZacharySutherby
Hello @Anonymous User,
Something similar to this can be accomplished with either an ArcGIS Experience builder application or ArcGIS Dashboards.
An ArcGIS Survey123 survey can be embedded in the application to edit existing submissions.
Please see these links for more information:
https://www.esri.com/arcgis-blog/products/experience-builder/real-time/using-experience-builder-and-...
https://doc.arcgis.com/en/experience-builder/configure-widgets/survey-widget.htm
https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-embedding-a-survey...
Thank you,
Zach
ZacharySutherby
Thank you,
Zach
by Anonymous User
Not applicable
Thanks for the information.   This is as close as I want to get to the example I showed.  Thanks so much!
