Showing or hiding repeats using conditional statements
2423
01-28-2022 03:16 PM
Jen_Zumbado-Hannibal
My questions should be simple. However, I'm not the best at formulas. I'm building simple map gallery contest form.
Some people submit two or more submissions under one name. Therefore, the behavior I'm looking for is if the participant answers:
Do you have more than one submission?
Yes
No
If 'yes' then show repeats as many times as necessary.
If 'no' then just show repeat once.
Or, maybe there is a better way to show repeats. I'm welcoming any suggestion @JamesTedrick ,  @IsmaelChivite , and other GIS Super Heroes.
Thanks everyone - Jen
Jen Zumbado-Hannibal, GISP
GIS Coordinator
City of Forest Grove
Forest Grove, OR 97116
2 Solutions
Katie_Clark
MVP Regular Contributor
Hi Jen,
I took a look at your survey, and what I think would be the best thing to do is just have a set of dependent questions for each option (Yes/No). So your current repeat (rows 16-29) would have a dependency of ${more_than_one_submission} = 'yes'. Then you'd have the same questions, but not in a repeat. And all of those would have a dependency of ${more_than_one_submission} = 'no'
Does that make sense/would that work for you regarding backend data processing?
Best,
Katherine
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
Sorry for the delay. This worked perfect! Thanks so much.
GIS Coordinator
Katie_Clark
Hi Jen,
Best,
Katherine
Best,
Katie
GIS Coordinator
