Show Group Depending on DropDown
1619
02-08-2017 02:47 AM
JohnMcConalogue
I have 4 groups, 1-4.
I also have a dropdown with 3 values, A,B,C
I want that only groups 1-3 appear when I select either A or B from the dropdown. But I want all 4 groups to appear if I select C.
In the 'relevant' field can I add ${dropdown='A' Or dropdown='B'}   ?
I know I can add the first bit but can the part in red be used also?
Thanks.
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Yes, you can accomplish what you're wanting, though it's a little different than what you typed above.  The correct relevant statement would be:
${dropdown} = 'A' or ${dropdown} = 'B'
The ${question_name} parts of the equation essentially mean 'the question/field with the name question_name'.  Also note that 'or' (as is 'and', 'not', and other function terms) are case sensitive -they need to be lower-cased.
Find attached a form that essentially accomplishes what you're specifying.
JamesTedrick
JohnMcConalogue
Thanks James.
