Set tab order for relevant select_one questions
145
3 weeks ago
Trippetoe
Two of the questions in my survey are: Wind Speed (number) and Wind Direction (select_one).  The Wind Direction question follows the Wind Speed question. It is 'relevant' and appears if the Wind Speed value > 0. The Wind Direction question is required when its relevant.
The 'problem' i'm having is that the form's Tab Order doesn't seem to include the Wind Direction question. For example, when a user enters a value >0 in the Wind Speed question and hits 'enter' (the blue arrow button on the number pad that appears for numeric questions), the tab skips right over the Wind Direction question. A user has to navigate back to the Wind Direction question. It's not a tragic situation for sure, but it is annoying for the users.
Is there a way to force a Tab stop for a relevant question? Ideally, hitting the blue button on the Wind Speed question would tab to the Wind Direction question and pop open the drop down list of Wind Direction values.
Thank you
DougBrowning
No you cannot set tab order but please upvote my idea here.  https://community.esri.com/t5/arcgis-survey123-ideas/add-tab-order-to-survey123/idi-p/941555
It has been years though so not sure it will happen.  thanks
