Set default just like in Survey123
682
05-15-2018 01:46 PM
AlexP_
Hello,
I have Survey123 set as default field with drop down list. So whatever I submit, the field is ready as default. So for ArcMap 10.5.1 or ArcGIS Online, I want Survey123 the same way as set default. Please advise!  I am not sure what group to put this in.
Thank you!
JamesTedrick
Esri Esteemed Contributor
Hi Alex,
This can be accomplished through the use of feature templates - see Manage feature templates—ArcGIS Online Help | ArcGIS for more information.
JamesTedrick
Hi Alex,
Are you asking for default values while editing via ArcGIS Online's Map Viewer or another web app?
AlexP_
James,
Yes, that is correct. How do I set up default value while edit or submit a report via ArcGIS Online map viewer/ web app?  Just like Survey123.
JamesTedrick
Hi Alex,
