Set color of calculated value
528
9
3 weeks ago
Slamon
I am trying to set the color of a calculated value to be green.  It's a decimal field and a simple equation, but I'm not getting anywhere with the samples provided by Esri or in the reference tab.
This is what I have tried: <div style="color:green">round(sum(${REL_TOTAL_VOL}),2)</div>
but S123 just kicks back an error that is doesn't understand the string.
Neal_t_k
Honored Contributor
You would put the html in the label field and you might need to  adjust it a bit to meet  your needs.  Maybe something like this:
<div style="color:green">Total Event Volume (BBL): ${TOTAL_EVENT_VOL}</div>
Neal_t_k
Honored Contributor
Try this to see if it worker for you, put the calculation in a helper field.
helper field calculation = round(sum(${REL_TOTAL_VOL}),2)
then in a note field put the html formatting:
note field label = <div style="color:green">${helperfield}</div>
Slamon
It's still not liking something
Neal_t_k
Honored Contributor
Slamon
Wouldn't that set the color for just the label and not the calculated values in the box?
Neal_t_k
Honored Contributor
Slamon
What I'm trying to get is the values within the boxes to be green.
Neal_t_k
Honored Contributor
If you want you should be able to format more like a table like your picture using html, it would be trial and error for me, but it should be possible.  Or use multiple html tags to have a black label and a green value.
Neal_t_k
Honored Contributor
Might have to tweek some more and update the field names but here is an example of a html table format you can paste in the label field of your note:
<table border="1">
  <tr>
    <th>Total Event Volume (BBL)</th>
    <th>Total Event Oil Volume (BBL)</th>
    <th>Total Event Produced Water/Other Volume (BBL)</th>
  </tr>
  <tr>
    <td style="color:green">${TOTAL_EVENT_VOL}</td>
  </tr>
</table>
Slamon
Nevermind... I see where I went wrong with your example, and that should work.
