Selecting a Photo to Annotate
1170
10-26-2022 03:49 PM
FelixRubi
I am creating a survey that needs to default an image for a user to annotate. I have over 300 images that will be filtered down based on the users' answer to a few questions. The default column in survey123 connect allows me to default 1 image by its file name. Is it possible to enter a calculation in the default field? Is it possible to pull an image from a csv? What are some ideas on being able to load in a default photo?
IsmaelChivite
Esri Notable Contributor
If you load your 300 images into the media folder, you will be able to reference them and dynamically set the annotate question.
Check the sample in Survey123 Connect for details.
