select_multiple, relevant
1953
02-06-2024 09:33 AM
WFCAdmin
I have a simple question regarding a survey123 connect I am building, specifically a 'select_multiple' option.
If field staff catch a fish, they will search through a species list.
I want to provide a filter for "other" and "salmonid". This part is simple.
In the relevant column, I am using the following.
for salmonids I am using ${fish_type}=’salmonid’ and for other I am using ${fish_type}=’other’. This works great, no problems.
Occasionally, staff will document multiple fish, possibly one from each filter. In this case, I would like staff to be able to select both the 'other' filter and the 'salmonid' filter.
I have been trying different combinations but failing each time. I expect it should look something like this?
${fish_type}=’salmonid’ or ${fish_type}= (’salmonid’ and 'other')
If anyone has suggestions it would be much appreciated.
Thank you
DougBrowning
MVP Esteemed Contributor
Have you tried contains?
contains(string, substring)
Returns true if the given string contains the substring.
contains(${question_one}, 'red')
WFCAdmin
Thank you Doug,
Thank you Doug! I tried the following and it works great.
contains(${fish_type}, 'salmonid' or (’salmonid’ and 'other'))
DougBrowning
I think this is the correct syntax though.
contains(${fish_type}, 'salmonid') or contains(${fish_type}, 'other')
abureaux
MVP Frequent Contributor
Why not selected()? It is intended to be used with select_multiple for this purpose.
selected(${fish_type}, 'salmonid')
EDIT: I will add that contains() does work in places that selected() doesn't, such as a WHERE clause for an Inbox survey. But in this particular case, I'd go with selected() as the standard for ALL select_one and select_multiple.
DougBrowning
Oh yea duh this is for a relevant.  So yea that is the better way really.
