Does search() not render properly using a dynamic-grid setting? I've got a functional search() setup that is working great now but when I try to implement it as a repeater into my form it is not spanning across the width I tell it to. The data type for this is select_one.
I'm using a second repeater to collect text info and it works great. I threw in a second text repeater just below the functional one and found it to be fine as well. When I test this same search() outside of the grid system it works well. This makes me think there is some kind of compatibility issue going on but I have not been able to find documentation on this.
Any info?
Hello @Aguirre_WOG,
Select_one questions with the search() appearance should work using the dynamic-grid setting in a repeat. Here is a modified version of the search() sample we have in Connect with dynamic-grid.
Hey Zachary, thanks for getting back with me. It makes sense but I am not able to get this to function as needed. I'm using two repeaters - one for "contacts" and the other for "firs numbers". The contacts repeater works like a charm but the firs repeater--which uses search() will not display properly in the field app. I've attached the file for you to take a look (rows 38-40). In addition, I've played with the widths quite a bit but cannot get it to respond as needed. Any feedback would be greatly appreciated.
I've continued playing with this and have found that I can appropriately view the search appearance values when I modify the setting to pages and apply field-list. Fixed-grid, dynamic-grid, pages fixed-grid and pages dynamic-grid give the same problem...The only style within settings that is working with this is "pages".
