S123 Template Reports 'Where' under $layers
415
02-19-2026 06:43 AM
TheoHorton
Hi there
I have got a feature service for wildlife patrols with three layers - one was used to create an S123 form (patrol_summary), the other two layers (patrol_route and wildlife_sightings) were used to create a quick capture project.
Once data has been captured using QC you would then fill out the patrol_summary survey and as they are in the same feature service you are able to reference the QC layers in the survey123 word template to create a patrol summary report.
I have managed to use the following to successfully produce a table that lists all of the wildlife sightings in the QC layer.
SpeciesAge / Sex GroupNumber Seen
${#$layers[“wildlife_sightings”]}
${species}
${age_sex}
${no_seen}
However, this returns ALL of the wildlife sightings. I have tried to filter the wildlife sightings using the where function and the shared 'patrol_id' field which links all the layers. See below.
${#$layers[“wildlife_sightings”]|where:"patrol_id='${patrol_id}'"}
This however does not work. I have confirmed I can do this if I input the actual patrol_id number eg. ${#$layers[“wildlife_sightings”]|where:"patrol_id=20260218-1931-TH"} but the dynamic capabilities of using ${patrol_id} which is selected during the patrol_summary survey does not appear to work.
Is this not possible and if so is there a work around?
Thanks.
TheoHorton
Thanks for the response Neal.
ESRI support actually managed to come up with the solution for this one.
Species
Age/Sex Group
Number Seen
${#$layers[0]}
${if $layers[5].patrol_id == $layers[0].patrol_id }
${species}
${age_sex}
${no_seen}
Neal_t_k
MVP Regular Contributor
Those SQL statements can be finicky, try one of thse:
${#$layers[“wildlife_sightings”]|where:"patrol_id='"${patrol_id}"'"}
${#$layers[“wildlife_sightings”]|where:"patrol_id='"+${patrol_id}+"'"}
You may also have to tell it which layer patrol_id is coming from:
https://community.esri.com/t5/arcgis-survey123-questions/summary-section-where-doesn-t-work-with-que...
TheoHorton
Species
Age/Sex Group
Number Seen
${#$layers[0]}
${species}
${age_sex}
${no_seen}
Teresa_Blader
Is your layer [0] this patrol summary you are querying against wildlife summaries [5]? Or the opposite? Thanks!!
Teresa Blader
Olmsted County GIS
GIS Analyst - GIS Solutions
