Hi there
I have got a feature service for wildlife patrols with three layers - one was used to create an S123 form (patrol_summary), the other two layers (patrol_route and wildlife_sightings) were used to create a quick capture project.
Once data has been captured using QC you would then fill out the patrol_summary survey and as they are in the same feature service you are able to reference the QC layers in the survey123 word template to create a patrol summary report.
I have managed to use the following to successfully produce a table that lists all of the wildlife sightings in the QC layer.
| Species | Age / Sex Group | Number Seen |
${#$layers[“wildlife_sightings”]} ${species} | ${age_sex} | ${no_seen} ${/} |
However, this returns ALL of the wildlife sightings. I have tried to filter the wildlife sightings using the where function and the shared 'patrol_id' field which links all the layers. See below.
${#$layers[“wildlife_sightings”]|where:"patrol_id='${patrol_id}'"}
This however does not work. I have confirmed I can do this if I input the actual patrol_id number eg. ${#$layers[“wildlife_sightings”]|where:"patrol_id=20260218-1931-TH"} but the dynamic capabilities of using ${patrol_id} which is selected during the patrol_summary survey does not appear to work.
Is this not possible and if so is there a work around?
Thanks.
Solved! Go to Solution.
Thanks for the response Neal.
ESRI support actually managed to come up with the solution for this one.
Species | Age/Sex Group | Number Seen |
${#$layers[0]} ${if $layers[5].patrol_id == $layers[0].patrol_id } ${species} | ${age_sex} | ${no_seen} ${/} ${/} |
Those SQL statements can be finicky, try one of thse:
${#$layers[“wildlife_sightings”]|where:"patrol_id='"${patrol_id}"'"}
${#$layers[“wildlife_sightings”]|where:"patrol_id='"+${patrol_id}+"'"}
You may also have to tell it which layer patrol_id is coming from:
