Reverse Geocode Not Working
3575
01-08-2021 10:33 AM
dedgar_polk
My reverse geocode within my form, that auto populated the nearest address, has stopped working.  I checked the sample reverse geocode form available within Survey123 Connect and I get the following error.
{"error":{"code":500,"message":"Error performing reverse geocode operation","details":[]}}
Any help would be greatly appreciated.
Dale
Shwu-jingJeng
Hi Dedgar,
Could you provide more detailed information so that we could narrow down the issue here?
What version of the Survey123 are you using? Did the reverse geocoding issue haapen on both Connect and field app using the same form? Is the survey hosted on AGOL or on enterprise portal? What OS are you using when the issue occurred?
dedgar_polk
Hi Shwu-jing,
I am using version 3.10.239 of connect. The is on the field app, connect is on a computer without GPS so it can't pull the location for the reverse geocoding.  The survey is on our enterprise portal (10.7.1).  We are using Apple iOS (various versions).
Shwu-jingJeng
Hi Dedgar,
As you are using enterprise portal, could you double check the default geocode service setting in this portal and make sure the user you signed in to the field app has the geocode permission assigned? Is the survey public? What version of the survey123 field app is the Apple device running on? What exact error did it show on the phone when the reverse geocode failed to run?
dedgar_polk
Hi Shwu-jing,
It's fixed.  The default geocode service was changed.  Thanks for the help!
