Reuse a repeat later in survey
641
02-27-2024 04:21 AM
jbyrne
Hi All
I'm trying to model out a survey where I want to shunt certain records into a related table.
However, due to the design, the survey needs to ask several unique guiding questions before getting to the section that needs to be added to the related table, and then start a new section with its own unique guiding questions.
I've been looking at repeats to move records to a related table, however grouping all the repeat questions into a single section doesn't really work with the design due to the afore mentioned unique guiding questions.
1) Is there a way to reuse the repeat at various stages of the survey
Or
2) is there a different way to move records to a related table
abureaux
MVP Frequent Contributor
1) No.
2) Kind of. Process automations may help, but would likely be convoluted. Just adding to a repeat would be easiest.
May help to see your survey design.
DougBrowning
You could try using pages but keep the repeat outside the pages and so then it is always at the bottom.  Then use esri hidden column to show it when needed.  About all I can think of.
